Date/Time: Fri, 24 Jan 2025 03:40:17 +0000
[User Discussion] - Any way to export data that I see in this chart?
View Count: 691
[2018-12-29 00:26:41] |
User502498 - Posts: 33 |
Hello. This is a 25T PNF chart that uses the numbers bars study to graph and show the delta. Is there anyway to get this information into a spreadsheet? So what I would like is for each bar to see a OLHC, the price levels in the bar, and the associated delta that is displayed. In other words, the data that makes up the essance of the bar, in a spreadsheet. I tried the spreadsheet study, but I don't think it's doing what I'm looking for. |
2018-12-28_16-25-23.png / V - Attached On 2018-12-29 00:25:38 UTC - Size: 32.43 KB - 367 views Attachment Deleted. |
[2019-01-02 22:57:45] |
ForgivingComputers.com - Posts: 990 |
It depends on what kind of spreadsheet you want. AFAIK the Sierra spreadsheet studies do not support numbers bars, which is basically what you want to see. An ACSIL custom study could be written to read the numbers bars and create a text file that can be imported into an Excel spreadsheet. It is simplest to use range bars in order to have a fixed number of price levels per bar. Depending on what you want the final spreadsheet to do, if you want auto-trading signals, a system could be written into the ACSIL study to handle that. |
