Date/Time: Fri, 24 Jan 2025 00:47:34 +0000
Global Profit / Loss Management - flatten based on %
View Count: 659
[2018-12-28 10:38:54] |
User7817001 - Posts: 96 |
In the book 'One Good Trade' from OBS contains two (2) great rules to control the down side, OBS enforces these rules on all speculators. Sierra Charts Global Profit / Loss Management has both, nearly both, which is great. 1) Daily Net Loss Management, no changed needed, 100% match with OBS 2) Daily Net Profit Management > Trail Daily Net Profit, an addition needed, add % to the existing $ you have, please see attachment for details Adding a field for % will provide a linear trail, the current $ is non-linear thank you mark |
Capture.JPG / V - Attached On 2018-12-28 10:38:01 UTC - Size: 160.84 KB - 282 views |
[2018-12-28 19:01:39] |
Okay we will see about this.
