Date/Time: Fri, 24 Jan 2025 00:38:55 +0000
Pivot Moving Average
View Count: 1020
[2018-12-28 02:35:47]
User417302 - Posts: 67
I was wondering if someone could help me this. I would like to create a simple moving average that is calculated based off the (high+low+Close)/3. Any help with this would be greatly appreciated.
Thanks,
[2018-12-28 05:58:52]
User90125 - Posts: 715
Go to Analysis >> Studies and find the Moving Average - Simple study. Add it to your chart and change the Input Data setting to HLC Avg, and select your desired Length as well. This should work for you.
[2018-12-28 09:24:32]
Yes that is the correct answer.
