Date/Time: Fri, 24 Jan 2025 00:24:03 +0000
Returning Customer need Help with Data Service
View Count: 578
[2018-12-27 19:38:40] |
User417302 - Posts: 67 |
Good afternoon, I hope all is well, I was a customer and am now returning next month. I had a quick question regarding data services. I am opening an account with Optimus Futures and will be running the CQG data feed into the platform for futures data access and trading. My question however revolves around equities. I am thinking about subscribing to the SC equity data feeds and my question is the following: can I run both feeds simultaneously? I wasn’t sure if I would be able to have 2 consecutive data feeds going on the same instance of Sierra at the same time. If it is not possible, how would I go about doing it? Is there an additional cost involved even if it’s on the same computer running at the exact same time? By the way your platform is awesome and keep up the great work. Thanks, |
[2018-12-27 20:53:25] |
Yes you can use CQG and also use the Sierra Chart Exchange Data Feed at the same time for US equities data and receive all of that data in a single installation of Sierra Chart . This is explained here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices No additional cost other than the cost of the data feed itself and the exchange fee. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-27 20:54:09
