Date/Time: Fri, 24 Jan 2025 00:36:35 +0000
SGX
View Count: 1078
[2018-12-27 16:04:34] |
EthanC - Posts: 44 |
Does Sierracharts provide end of day data for this exchange?
[2018-12-27 20:02:37] |
If you are looking for futures, the answer is yes and the futures base symbols can be found here: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Futures#SIMEX Also refer to: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php#Notes_FuturesSymbolFormat We will also make sure these are listed in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-27 20:03:25
[2018-12-28 00:28:31] |
How about equities and indexes?
[2018-12-28 00:45:37] |
No, those are not supported.
