Date/Time: Fri, 24 Jan 2025 00:33:43 +0000
MA-Time Period
View Count: 634
[2018-12-27 16:03:03] |
KXRCap - Posts: 64 |
I am confused on your new Moving Average. I am using 1000 minutes with Last. I put it on a 233Tick chart and I get a different calculation if I put it on a 4-2-0 Renko. And neither are the same as if a put a 1000 bar moving average on a 1 minute chart? Please explan what is actually getting calc'd.
[2018-12-27 22:46:09] |
Refer to the documentation here: Moving Average - Time Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
