Date/Time: Fri, 24 Jan 2025 00:30:44 +0000
Transfer Control Bar & Keyboard Shortcuts to New Instance
View Count: 2008
[2018-12-26 15:49:40]
tdd2672 - Posts: 61
How can the Control Bar settings and Keyboard shortcuts be moved to a new instance.
When I copy and paste the Sierra3.cfg and the KeyboardShortcuts file nothing changes. Is there another file/s that need to be moved as well?
Date Time Of Last Edit: 2018-12-26 16:09:09
[2018-12-26 18:15:00]
Refer to this help topic:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
Make sure Sierra Chart is not running when you copy those files. Those are the correct files.
[2018-12-27 15:57:58]
tdd2672 - Posts: 61
Will this work for sub-instances as well? I moved the specified files but the sub-instance did not change.
[2018-12-27 20:04:41]
Yes absolutely. Make sure both instances of Sierra Chart are not running, both the source and destination instances, and copy those configuration files to the sub instance installation folder.
