Date/Time: Fri, 27 Sep 2024 03:50:40 +0000
Daily bid/ask volume
View Count: 1435
[2018-12-26 15:28:15] |
User49270 - Posts: 48 |
Hi, is there a way to scan for stocks where the daily ask volume is greater than the bid volume? Thanks.
[2018-12-26 17:54:34] |
You would need to use Intraday charts for this where the chart bars are set to 1 day per bar: Chart Session Times: Creating Daily Bars with Custom Session Times For scanning, refer to: Study/Chart Alerts And Scanning: Scanning for Alert Condition Across Multiple Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-05 13:26:47] |
User999647 - Posts: 38 |
I got the same question - bid ask volume showing on 4H and below frequency. However, they would not show for daily or weekly charts. As mentioned, I have opened intraday chart and set the bar to daily, bid and ask volume still are not showing. Any suggestions? Thanks a lot.
[2019-04-05 17:33:50] |
Most likely because it is a chart based on historical daily data still. Set the Chart Data Type to Intraday Chart Only: Chart Settings: Chart Data Type (Chart >> Chart Settings >> Data Limiting >> Date Range and Limiting Method menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-06 20:05:09] |
Thanks a lot, it is very helpful. A further question on this please. Obviously you could set the number of days a bar includes. However, the number is fixed as was set to a particular number, say 30. If I wanna see the ask volume on a the previous calendar months (different months are with different days, so setting a specific number of days would not work), is there a way to realise? Thanks a lot. |
[2019-04-08 20:36:51] |
You need to use the Monthly Bar Period Type which is supported for Intraday Charts: Chart Settings: Time Period Per Bar / Amount of Data Per Bar (Chart >> Chart Settings >> Bar Period menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
