Date/Time: Fri, 24 Jan 2025 00:32:46 +0000
[Programming Help] - attaching a trailing stop order to an already Filled order in ACSIL
View Count: 756
[2018-12-25 18:11:59] |
User525733 - Posts: 126 |
Hi, Is it possible to submit and link a trailing stop or target chase order to an already filled order using ACSIL? if so how? is there a way we can manually set ParentInternalOrderID/LinkID of for the stop/target orders? thanks |
[2018-12-26 03:19:14] |
a response is appreciated
[2018-12-26 10:24:45] |
Marmany - Posts: 307 |
Bret Johnson kindly released source code for a trailing stop which will at least give you a base to work from. Offering To The Community: Brett's Multi-Function Trailing Stop |
