Date/Time: Fri, 24 Jan 2025 06:38:22 +0000
Is C++11 compatible with Sierra Chart studies?
View Count: 1131
[2018-12-25 12:04:36]
doetrader - Posts: 13
[2018-12-25 12:07:29]
ganz - Posts: 1048
doetrader
yes.
Remote Build - Error SC version 1689 | Post: 141378
[2018-12-25 12:24:37]
What about C++14 and C++20?
[2018-12-25 16:41:17]
The question itself inherently does not make sense because such a compatibility limitation cannot even exist to begin with. The custom study interface Sierra Chart provides is C++ so the particular C++ language standard you are using is irrelevant.
The only potential compatibility issue would be the other way around where if the custom study interface were to use certain c++ standard features which requires a particular more recent version but this is not the case.
Date Time Of Last Edit: 2018-12-25 17:24:31
[2018-12-25 17:21:04]
ganz - Posts: 1048
doetrader
2. Current gcc version shipped with Ubuntu 16.04.
check for ver. 5.3 status
https://gcc.gnu.org/projects/cxx-status.html
Date Time Of Last Edit: 2018-12-25 17:21:43
[2019-01-12 13:04:35]
ganz - Posts: 1048
doetrader
https://gcc.gnu.org/onlinedocs/libstdc++/manual/status.html
