Date/Time: Mon, 27 Jan 2025 19:43:15 +0000
Alert Manager missing Minimize and Maximize buttons
View Count: 1327
[2018-12-23 14:04:03] |
User360283 - Posts: 506 |
V 1853-32 bit Can't minimize Alert Manager Please fix Thanks |
[2018-12-23 16:54:51] |
This will be solved in the next release.
[2019-03-04 13:13:18] |
V 1880 32-bit Not fixed Help please |
[2019-03-04 16:38:25] |
We understand the reason for the problem and this will be resolved in the next release.
