Date/Time: Fri, 24 Jan 2025 00:43:45 +0000
Connection Question
View Count: 579
[2018-12-23 07:57:16] |
User140818 - Posts: 4 |
Dear support My AMP Futures account nr 114917 was refunded now and I want to stay with using your sierra advanced chart software version nr 1843 and book reduced CME Bundle with CQG real time data as non professional trader from 1 st of January onwards. So I wait now till 1st of January and then follow your connecting instructions as I am not interested to pay for end of dec. real time data As I understand from your last ticket it is no problem to connect CQG data directly to my Sierra software following your instructions. Hope it will work My question: Do I have to inform AMP Futures about this as well? Thanks in advance for reply Date Time Of Last Edit: 2018-12-26 19:19:06
[2018-12-26 19:18:55] |
No it does not sound like you need to inform AMP, unless you have any connection issues to CQG. Here are the set up instructions for that: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-26 19:19:46
