Date/Time: Fri, 24 Jan 2025 00:42:16 +0000
Symbol settings reverting back to default
View Count: 757
[2018-12-21 19:29:00] |
arruga - Posts: 253 |
Hi there. There's an issue with my symbol settings; I customize them via global settings--> symbol settings, where I re-define session times... all good. After some time (few days), I open my SierraChart and the settings are back to default (session times back to default)... it's happened already a few times. They keep reverting back to default as though there's an automatic trigger that updates my settings to align with server settings, which is not what I want. Please advise. Once I edit my symbol settings for all my symbols, is there any way to save them in a settings file so I can reload settings off of it in case they get lost? Thanks a Date Time Of Last Edit: 2018-12-21 19:32:09
[2018-12-22 21:18:17] |
Refer to: https://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#PreventingAutomaticUpdatingOfSymbolSettings Global Symbol Settings: Making a Backup of Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-23 23:12:49] |
Thanks for reply. I believe the first link you sent is pointing to section: #PreventingAutomaticUpdatingOfSymbolSettings, but such section doesn't exist. What does exist is: "Preventing the Changing of Intraday Chart Session Times", but this does not address the issue I'm having. I have set session times through global settings --> symbol settings, and always want to use those.The problem I'm having is that those session times within global settings--> symbol settings are reverting back to, I can only assume, server settings (as though there was an automatic server update trigger being set somewhere. |
[2018-12-23 23:15:15] |
You were looking at an older page. We have now updated it. Here are the instructions again: https://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#PreventingAutomaticUpdatingOfSymbolSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-23 23:15:31
