Date/Time: Fri, 24 Jan 2025 01:42:45 +0000
Can't enable volume bar for Dom Ladder
View Count: 1090
[2018-12-21 03:20:14] |
User682449 - Posts: 2 |
Hi, How to enable volume bar(horizontal histogram) for all the columns in the dom ladder ? I am currently using the last Sierra Chart release(1852) and can't see such an option in "Chart Dom Settings" ? In "Graphics Settings" I can see Volume Bar entries for each columns in the Dom, but the "Enable box" is not active. Thank You |
[2018-12-21 15:28:22] |
John - SC Support - Posts: 37448 |
Turning on the Volume Bars is controlled in the Customize Chart/Trade DOM Columns page. Refer to the following: Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
