Date/Time: Fri, 24 Jan 2025 01:45:37 +0000
2 sheets in same spreadsheet updating on each candlestick.
View Count: 594
[2018-12-20 22:32:11] |
User452567 - Posts: 38 |
Is it possible to have 2 sheets in same spreadsheet updating on each candlestick? Which configuration should I set up? Thank you
[2018-12-20 22:57:40] |
Yes. You just need to use two instances of the Spreadsheet Study on the same chart and each one referring to the same named Spreadsheet file. Refer to: Using the Spreadsheet Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
