Date/Time: Fri, 24 Jan 2025 01:46:26 +0000
Find Symbol does not show another instance of data vendor
View Count: 1282
[2018-12-20 06:16:06]
User189399 - Posts: 43
My computer is running several SC instance connecting to different Data/Trade Vendor. Once I updated one of SC to the current version. The "Find Symbol" cannot show another instance/vendor Symbols (SC_updated.jpg). Before update, it normally show as the SC_not_updated.jpg. Since I need to get the symbol from different instance to the instance working for trade vendor, I need this function back. Pls advise how I can fix it.
imageSC_updated.jpg / V - Attached On 2018-12-20 06:10:31 UTC - Size: 112.29 KB - 320 views
imageSC_not_updated.jpg / V - Attached On 2018-12-20 06:14:45 UTC - Size: 106.76 KB - 282 views
[2018-12-20 07:39:30]
This is explained here and a link to the documentation with the new functionality which replaces this:
Breaking Change: Remote Chart Data Files
Here is the documentation for the new functionality:
https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart
Date Time Of Last Edit: 2018-12-20 07:40:14
