Date/Time: Fri, 24 Jan 2025 01:44:30 +0000
How to gather Triggered Alert condition, Bar Number and Time data in a single file
View Count: 825
[2018-12-20 04:10:22]
TXG8R - Posts: 3
I have an alert using the "Color Bar Based On Alert Condition" study. I am also using the "Bar Numbering" Study, where the "Do Not Reset at Start of New Day" property value is "Yes".
What is the best way for me to gather:
A list of the bars by Bar Number, whether the alert fired on that bar (the visual signal is persistent after the bar has finished printing), and the time the bar initially started/printed.
My business purpose is to gather statistics on how many bars are printed between signals.
Any guidance would be greatly appreciated.
[2018-12-20 17:40:32]
Probably would be a good idea to use the Spreadsheet Study for this:
Overview of Spreadsheet Studies
And then all of the data is there on a Sheet and then you can work out some formulas to get what you need.
Otherwise, you would need to use ACSIL:
Advanced Custom Study Interface and Language (ACSIL)
Date Time Of Last Edit: 2018-12-20 17:41:10
