Date/Time: Sun, 24 Nov 2024 15:50:44 +0000
time line study custom text can change size?
View Count: 1482
[2013-11-08 04:22:43] |
4646ed - Posts: 230 |
How do you change the size of the text in the time line study custom text?
[2013-11-12 02:33:42] |
Hello?
[2013-11-12 04:45:11] |
We needed time to look into this. It cannot be changed but we are going to add a new Study Subgraph to allow you to customize the color and the size.
[2013-11-12 04:46:14] |
[2013-11-15 08:48:31] |
Just got 1046. It took me a few minutes to figure out since the default settings of 6 for vertical position and 1 for width make the label impossible to see. just a wee dot. you might want to make the defaults 20 and 10 respectively. thanks again. Date Time Of Last Edit: 2013-11-15 08:49:38
[2013-11-15 09:19:58] |
The default Text Size when you add the Time Line study to the chart is 0 which internally translates to 10 or 12 points.
[2013-11-15 09:21:36] |
So with the default you should be able to see it, no?
