Date/Time: Fri, 24 Jan 2025 00:33:24 +0000
Replay at Every Tick is not asking for Processing Step in Seconds
View Count: 786
[2018-12-19 15:39:06] |
ForgivingComputers.com - Posts: 990 |
A client is seeing different dalog boxes than me in Tick by Tick replay: mine asks for the processing Step n Seconds, and his does not. Both are on 1852.
Date Time Of Last Edit: 2018-12-19 15:40:54
[2018-12-19 17:59:36] |
The difference has to do with whether or not more than one chart is being replayed. That prompt only occurs when more than one chart is being replayed. Refer to: https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ChartsToReplay Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
