Date/Time: Fri, 24 Jan 2025 00:31:54 +0000
Copy drawings from instance to instance
View Count: 1206
[2018-12-19 10:25:40] |
samual sprat - Posts: 343 |
Hi, Will this functionality to copy drawings from one instance to another instance be available soon? Think I read this was in the todo list Thanks S |
[2018-12-19 17:38:37] |
This was never said. No this is never going to come.
