Date/Time: Fri, 24 Jan 2025 00:45:57 +0000
sc.GetChartStudyInputInt() error?
View Count: 715
[2018-12-18 21:56:29] |
User30743 - Posts: 365 |
hi i would like to ask why i am getting this error when using the function sc.GetChartStudyInputInt(). i just copy and paste the code from the example provided in your documentation here sc.GetChartStudyInputInt() and it doens´t work since there are too many arguments.. do u have any idea why is it so? |
getchartstudyinputint.png / V - Attached On 2018-12-18 21:55:02 UTC - Size: 5.08 KB - 275 views |
[2018-12-18 22:54:09] |
Your code looks OK. Make sure you are running the current version of Sierra Chart and using the latest header file (sierrachart.h).
[2018-12-18 22:54:10] |
[2018-12-19 09:49:55] |
i upgraded (version 1852) and the error still perzists
[2018-12-19 10:26:04] |
moreover the newer version keeps returning denied error for no reason.. so i will rather downgrade again
[2018-12-19 22:01:02] |
Refer to: Advanced Custom Study Interface and Language (ACSIL): Modifying Advanced Custom Study Code Newer versions of Sierra Chart have a new way to solve this. The documentation has been updated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
