Date/Time: Fri, 24 Jan 2025 00:55:28 +0000
chart jumps up & down when reaching top or bottom of chart area as new bar forms
View Count: 748
[2018-12-18 16:34:36]
User635423 - Posts: 51
Hello, I am currently using a Flex Renko chart that jumps up and down when reaching the top or bottom of the chart area as a new bar is forming. For example on a long - a bar is forming at the top and then pulls back a bit - price bars drop down to allow it to go up and then the pull back - and the price bars go back up. (it moves the chart up and down quickly)
Please direct me on how I can change that so that it does not jump. Works just fine in the middle but drives me crazy when approaching top or bottom.
The studies I've enabled are as follows Reg 1 - Ichimoku, CS Hedge Fund and Momentum Shift as well as some MA's. Reg 2 MACD. Reg 3 Stochastics, RSI.
Is there a way to fix or adjust?
Thank you
[2018-12-18 18:14:49]
Make sure the Scale Range of that chart is set to Automatic:
http://www.sierrachart.com/index.php?page=doc/Scaling.html#ScaleWindowMainPriceGraph
Some of the studies you mention also are custom studies. Make sure those use a Scale Range of Same as Region:
http://www.sierrachart.com/index.php?page=doc/Scaling.html#ScaleWindowStudy
