Date/Time: Fri, 24 Jan 2025 20:40:38 +0000
Sierra Support: Error
View Count: 758
[2019-02-04 02:31:35] |
User578130 - Posts: 1 |
My account is KennyKwok, mbut my programme does not run automatically although i hae re-activate it, please help to run it NOW, thanks.
[2019-02-04 02:51:18] |
Your Sierra Chart account is active and also the Sierra Chart Exchange Data Feed is active with the Hong Kong futures data exchange. So everything is fine on your account. You might need to restart Sierra Chart. So do that and let us know if you need further help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
