Date/Time: Fri, 24 Jan 2025 00:34:55 +0000
Chart Settings / Session Times / Globex ES
View Count: 1873
[2018-12-18 14:34:27] |
User371906 - Posts: 141 |
Hello, I am trading F.US.ENQH19 Globes session and I am unable to ascertain after reading the SC guide lines on the different web pages as what Session Time to place as correct in Chart Settings. Chart 1. If I place in Chart Settings Start Time: 00:00:00 - End Time: 23:59:59 (Unchecked Evening Session) http://www.sierrachart.com/image.php?Image=1545143431395.png I get a complete different set of candles. Chart 2. If I place in Chart Settings Start Time: 09:29:00 - End Time: 23:59:59 (Checked evening Session) Evening Session: 16:15:00 - Evening End: 09:29:59 I also get a complete different set of candles. http://www.sierrachart.com/image.php?Image=1545143379376.png Could you please tell me what settings are correct. I trade out of Europe/Poland Attached are Chart Settings. Thank you Regards g Date Time Of Last Edit: 2018-12-18 14:35:16
Chart 1 Settings.JPG / V - Attached On 2018-12-18 14:31:36 UTC - Size: 172.06 KB - 491 views Chart 2 Settings.JPG / V - Attached On 2018-12-18 14:31:51 UTC - Size: 179.05 KB - 471 views |
[2018-12-18 18:20:53] |
The settings that are correct, are the settings that you want to use. This is for you to decide. Refer to: http://www.sierrachart.com/index.php?page=doc/SessionTimes.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
