Date/Time: Sun, 24 Nov 2024 12:48:17 +0000
Highlighting area on charts
View Count: 1531
[2013-11-07 21:13:23] |
sta321 - Posts: 1 |
Hello, is there a way to highlight a particular time or area on a chart where I can look back and remember where I marked the chart?
[2013-11-08 15:56:48] |
bwasi - Posts: 34 |
if your time is fixed at certain time then use Analysis >Studies > Time Line if you want to mark at will..use Tools > Marker (you can use marker icon..customize toolbar..right click icons) |
[2013-11-08 17:00:02] |
Look at using the Highlight drawing tools: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#RectangleEllipseTools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
