Date/Time: Fri, 24 Jan 2025 07:19:06 +0000
number bars calculated values
View Count: 1210
[2018-12-18 14:33:24]
User884550 - Posts: 149
i have a footprint chart for large lots, and calulated values are copied to default chart as study/price overlay,
large trade delta per bar does show OK, but values from large lot pullback column are not copied
how to fix that?
chart are in bar period
imagenumb bars.png / V - Attached On 2018-12-18 14:32:54 UTC - Size: 97.37 KB - 315 views
[2018-12-18 23:10:01]
The way to accomplish this is documented here:
Numbers Bars: Overlaying a Numbers Bars Calculated Values Study from Another Chart
[2019-01-09 13:34:53]
i have done all as per instructions, but it still gives 0 into destination chart
imagenumb bars.png / V - Attached On 2019-01-09 13:34:45 UTC - Size: 207.61 KB - 327 views
[2019-01-10 03:47:30]
Provide us the Chartbook you are using and we will look at this. Here are instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2019-01-10 09:38:33]
have recreated everything from scratch, now it works
