Date/Time: Fri, 24 Jan 2025 00:25:59 +0000
[Locked] - Trade activity Log - *trades
View Count: 953
[2018-12-18 08:44:42] |
User51166 - Posts: 33 |
Hi, Trade activity Log - *Trades: need to be sorted by date not by contract month, we need check how many wining trades in row we have, see attachment. Updated trade activity log is simply disaster previous version 1800 was perfect. Date Time Of Last Edit: 2018-12-18 08:48:21
[2018-12-18 18:50:13] |
You can determine the winning trades in a row by looking at the Streaks data on the Trade Statistics tab. And to refer to critical core improvements in the Trades list and Trade Statistics, as a disaster is completely wrong. We make no apologies about this whatsoever. If Sierra Chart does not meet your needs please go elsewhere. Do not post further again about this. And in any case you can get the result data that you need from the Trade Statistics tab. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-18 18:50:50
[2018-12-18 20:06:09] |
To give you some further background, the reason why each symbol and trade account is now separate on the Trades tab is that these are tracked in separate containers which is how it has to be done for proper organization and for performance reasons. When users complain to us about this and especially the way that you are, it is not taken well at all because there were significant issues with the implementation of the Trades calculations that have been resolved in a durable way. This is properly serving the needs of our user base. Here we are fixing problems and users are complaining. The changes are absolutely essential and cannot change. You can get the data you need in the Streaks information but that is going be based upon fill to fill order matching but we can always improve upon that and also support a Flat to Flat fill grouping. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-18 20:06:50
