Date/Time: Thu, 23 Jan 2025 21:25:27 +0000
Dom Graph Position Volume totals and Percentages
View Count: 1128
[2018-12-18 07:30:55] |
User551971 - Posts: 34 |
is it possible to change the position of total volume and percent.
Dom_On_graph_info.png / V - Attached On 2018-12-18 07:30:36 UTC - Size: 12.87 KB - 308 views |
[2018-12-18 10:46:48] |
No, that is not controllable. You can have a look at the Market Depth window to view this data in a table type view: File Menu: Open Market Depth Window (File) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
