Date/Time: Thu, 23 Jan 2025 21:24:31 +0000
Sierra Chart Remote Build and Dialog Box Templates and Resource Template/Files
View Count: 631
[2018-12-18 07:17:58] |
doetrader - Posts: 13 |
If I have a Dialog Box template / resource templates connected in my ACSIL study, will the DLL still be built fine by the Sierra Chart Remote Build options?
[2018-12-18 08:54:33] |
No, this is not supported. You need to use Visual C++ externally.
