Date/Time: Thu, 23 Jan 2025 21:39:29 +0000
[User Discussion] - Ubuntu 18.04.1 LTS - Trade Window "Encountered an improper argument"
View Count: 730
[2018-12-18 06:21:27] |
User922109 - Posts: 2 |
Limit order box shows as 0.0 instead of quoting the current price. When attempting to change the quantity box I get a popup that says "Encountered an improper argument" Happens in chart replay mode as well as live. Sent a log. |
sierra_issue.png / V - Attached On 2018-12-18 06:19:20 UTC - Size: 45.27 KB - 267 views Attachment Deleted. |
[2018-12-18 07:12:23] |
Updating Sierra fixed the error even though it's still saying it is at the same version
[2018-12-18 08:51:39] |
We have marked this as a User Discussion and we declining support for this. You are just seeing a random behavior with the operating system you are using and it is not anything we can help with.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-18 08:51:56
