Date/Time: Sat, 25 Jan 2025 01:10:38 +0000
Mark Price on DOM from spreadsheet
View Count: 1509
[2018-12-17 23:10:53]
User294224 - Posts: 43
Could you tell me if it is currently possible to highlight a price on the DOM using the spreadsheet?
i.e. Is there anyway I could highlight the price $50 on the DOM using a function from the spreadsheet?
[2019-01-09 22:14:30]
Could anyone give me an answer on this?
[2019-01-10 01:20:56]
Sawtooth - Posts: 4162
This is not supported. On the DOM's menu, go to Chart >> Studies and you'll see only a few studies are supported.
[2019-01-10 01:27:50]
Post #3 is not correct. You can use any study. Refer to:
Chart Trading and the Chart DOM: Adding Studies on a Trade DOM
So just follow the instructions linked above to use the Spreadsheet Study on the Trade DOM. We apologize for not responding earlier. We thought what you wanted to do was not supported because you were referring to highlighting a price but as we think about it the Spreadsheet Study can be used to draw a line to the left of the market data columns and and/or include a Value Label in the price column at the price level of the line. So that effectively does what you want.
Date Time Of Last Edit: 2019-01-10 01:30:04
[2019-01-10 15:40:55]
Thank you for the reply. Regarding the spreadsheet study, I don't see it on the list of available studies for the Chart DOM. Is there anyway for me to add it?
[2019-01-10 19:37:28]
Yes of course. This is what these instructions here explain:
[2019-01-10 19:45:28]
No spreadsheet study is in the list at Add Custom Studies.
[2019-01-10 19:48:24]
Okay, we understand now. We will solve that in the next release.
[2019-01-10 21:30:35]
Not trying to rush you or anything but how long do you think it will be for the next release?
Thanks in advance
[2019-01-10 23:19:16]
By tomorrow morning.
[2019-02-09 21:01:16]
Yeager - Posts: 128
Hi, I’m hoping it is possible to highlight prices on the dom with several different colors. I would like to manually say CCTRL click a price once to turn it green, twice to turn it blue, 3 times to turn it orange. You get the idea.
[2019-02-10 20:34:19]
You can do this with the Line study and by enabling the Value label for the study. This is all documented here:
Line
You can add the study through Chart >> Studies on the Trading DOM.
Date Time Of Last Edit: 2019-02-10 20:34:31
