Date/Time: Thu, 23 Jan 2025 21:35:08 +0000
[User Discussion] - Order modification failed
View Count: 928
[2018-12-17 10:19:47]
T44 - Posts: 363
Hello Support,
Please find attached my trade activity log.
I do not see a reason in my configuration why this would have suddenly started happening, I have not altered any settings, other symbols are not affected.
I am using version 1837.
Thanks,
Private File
[2018-12-17 14:45:38]
Update Sierra Chart to the current version following these instructions here:
[2018-12-17 16:36:01]
T44 - Posts: 363
On loading the latest version, I was locked out of my exchange data feed because of too many consecutive login attempts.
Sierra kept reconnecting, same workspace as I was running before with no issues.
Hopefully a message log helps?
Private File
[2018-12-17 18:51:33]
T44 - Posts: 363
Sorry, this 'connection reset by peer' is a Wine/Linux/(possibly) Websockets issue.
Please ignore, we are going to be changing to the Sierra Chart data feed.
Also, we want to run a Windows cloud instance to avoid these Wine issues, and feed the Wine machines with a DTC bridge.
[2018-12-17 18:54:33]
Yes we can tell, that you are not running Windows and the connectivity issue is happening probably at the operating system level.
This is not a Sierra Chart issue in any way.
Date Time Of Last Edit: 2018-12-17 18:54:42
