Date/Time: Mon, 28 Sep 2026 12:09:34 +0000
[Programming Help] - What ACSIL array should I use for storing values used by another study but not displayed?
View Count: 1616
[2018-12-17 09:25:42]
User718622 - Posts: 57
I am writing an ACSIL study that uses dialog boxes to get necessary input that I cannot get otherwise. All input is an integer value. I need some place to store each input so that another, separate, ACSIL study can use it.
The input will not be displayed on the charts or graphs. It is solely for use in calculation by separate ACSIL study.
What ACSIL array should I use to store this data?
[2018-12-17 22:05:36]
These dialog boxes must be modeless otherwise Sierra Chart is going to abnormally shut down.
You should use persistent variables for these:
ACSIL Interface Members - Functions: sc.GetPersistentInt()
Date Time Of Last Edit: 2018-12-18 01:39:12
[2018-12-18 01:26:40]
Are you saying I should use persistent variables to keep track of input from a modeless dialog box?
