Date/Time: Fri, 24 Jan 2025 07:20:20 +0000
Sierra chart on two devices at the same time?
View Count: 930
[2018-12-16 23:56:09]
SurfTrader - Posts: 68
Trying to use SC on a laptop and my main computer at the same time and having problems. I am using a different data provider for each. Loads chart on the secondary device(laptop) but no movement and gives error code 32: the process cannot access file because it is being used by another process. Can I only run one one device at a time? If I disconnect from my main computer will I be able to use the data on my laptop?
[2018-12-17 05:23:39]
This error message is not related to using Sierra Chart on two systems. And if you are using different "Data" providers, then you are not getting disconnected from them due to simultaneous connections.
For help with that particular error, refer to:
http://www.sierrachart.com/index.php?page=doc/helpdetails16.html
[2019-01-10 00:50:09]
Still can not get sierra chart to connect to data feed and work on my laptop. To be clear I am simultaneously running SC on my main comp at the same time using interactive brokers Data and my laptop is trying to use TDA data, not sure if that makes a difference.
I have posted the message log below, let me know if you see any issues. Thanks
Reading Internal Order ID file. | 2019-01-10 00:40:51
Reading Trade Orders file. | 2019-01-10 00:40:52
Reading Trade Positions file. | 2019-01-10 00:40:52
Account Balance file. | 2019-01-10 00:40:52
Listening on UDP port 22904. | 2019-01-10 00:40:52
Software version: 1850 32-bit | 2019-01-10 00:40:52
Usage end date: 2019-02-11 | 2019-01-10 00:40:52
Enabled for: Advanced Features. | 2019-01-10 00:40:52
Enabled for: Advanced Features 2. | 2019-01-10 00:40:52
Enabled for: Sierra Chart Historical Data Service. | 2019-01-10 00:40:52
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-01-10 00:40:52
Current selected Data/Trading service: TD Ameritrade | 2019-01-10 00:40:52
Chart Update Interval: 500 | 2019-01-10 00:40:52
Time Zone: +00:00:00 (UTC+00) | 2019-01-10 00:40:52
2019-01-09 19:40:51 Local computer time | 2019-01-10 00:40:52
2019-01-10 00:40:51 Local computer time in UTC | 2019-01-10 00:40:52
2019-01-10 00:40:51 Local computer time in SC Time Zone | 2019-01-10 00:40:52
2019-01-10 00:40:49 Server time in UTC | 2019-01-10 00:40:52
Local computer UTC time and Server UTC time difference: 1 seconds. | 2019-01-10 00:40:52
Program path: C:\SierraChart\ | 2019-01-10 00:40:52
Data Files path: C:\SierraChart\Data\ | 2019-01-10 00:40:52
OS Version Number: 10.0 | 2019-01-10 00:40:52
Locale Setting: C | 2019-01-10 00:40:52
DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-01-10 00:40:52
Checking for new symbol settings for service code tda | 2019-01-10 00:40:52
HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2019-01-10 00:40:52
HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 46.4.97.203. | 2019-01-10 00:40:52
Received 5 login tokens. | 2019-01-10 00:40:53
Symbol settings are up-to-date for tda | 2019-01-10 00:40:53
HTTPS www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2019-01-10 00:40:54
HTTPS www.sierrachart.com:443 (5) | Connecting to IP: 46.4.97.203. | 2019-01-10 00:40:54
HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:40:55
HTTPS login.sierrachart.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:40:55
HTTPS login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-10 00:40:55
HTTPS login.sierrachart.com:443 (1) | Closed. | 2019-01-10 00:40:55
TD Ameritrade | Connecting. | 2019-01-10 00:40:58
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:40:58
HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-10 00:40:58
HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2019-01-10 00:40:58
HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-10 00:40:58
HTTPS www.sierrachart.com:443 (2) | Closed. | 2019-01-10 00:40:58
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:40:58
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:40:58
HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2019-01-10 00:40:58
HTTPS www.sierrachart.com:443 (4) | Signaling to core to close socket | 2019-01-10 00:40:58
HTTPS www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-10 00:40:58
HTTPS www.sierrachart.com:443 (4) | Closed. | 2019-01-10 00:40:58
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:40:58 *
TD Ameritrade | Login failed. | 2019-01-10 00:40:58 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:40:58
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:40:58
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:40:58
TD Ameritrade | Disconnected. | 2019-01-10 00:40:58
Disconnected from TD Ameritrade. | 2019-01-10 00:40:58
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:40:58
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:40:58
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:40:58
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:40:58
HTTPS www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2019-01-10 00:41:00
HTTPS www.sierrachart.com:443 (5) | Signaling to core to close socket | 2019-01-10 00:41:00
HTTPS www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2019-01-10 00:41:00
HTTPS www.sierrachart.com:443 (5) | Closed. | 2019-01-10 00:41:00
TD Ameritrade | Connecting. | 2019-01-10 00:41:01
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:01
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:01
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:01
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:01 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:01 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:01
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:01
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:41:01
TD Ameritrade | Disconnected. | 2019-01-10 00:41:01
Disconnected from TD Ameritrade. | 2019-01-10 00:41:01
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:01
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:01
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:41:02
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:41:02
TD Ameritrade | Connecting. | 2019-01-10 00:41:04
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:04
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:04
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:04
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:05 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:05 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:05
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:05
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:41:05
TD Ameritrade | Disconnected. | 2019-01-10 00:41:05
Disconnected from TD Ameritrade. | 2019-01-10 00:41:05
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:05
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:05
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:41:05
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:41:05
TD Ameritrade | Connecting. | 2019-01-10 00:41:08
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:08
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:08
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:08
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:08 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:08 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:08
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:08
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:41:08
TD Ameritrade | Disconnected. | 2019-01-10 00:41:08
Disconnected from TD Ameritrade. | 2019-01-10 00:41:08
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:08
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:08
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:41:08
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:41:08
TD Ameritrade | Connecting. | 2019-01-10 00:41:19
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:19
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:19
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:19
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:19 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:19 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:19
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:19
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:41:19
TD Ameritrade | Disconnected. | 2019-01-10 00:41:19
Disconnected from TD Ameritrade. | 2019-01-10 00:41:19
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:19
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:19
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:41:19
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:41:19
TD Ameritrade | Connecting. | 2019-01-10 00:41:22
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:22
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:22
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:22
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:22 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:22 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:22
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:22
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:41:22
TD Ameritrade | Disconnected. | 2019-01-10 00:41:22
Disconnected from TD Ameritrade. | 2019-01-10 00:41:22
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:22
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:22
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:41:22
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:41:22
TD Ameritrade | Connecting. | 2019-01-10 00:41:25
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:25
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:25
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:25
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:26 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:26 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:26
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:26
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:41:26
TD Ameritrade | Disconnected. | 2019-01-10 00:41:26
Disconnected from TD Ameritrade. | 2019-01-10 00:41:26
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:26
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:26
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:41:26
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:41:26
TD Ameritrade | Connecting. | 2019-01-10 00:41:29
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:29
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:29
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:29
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:29 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:29 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:29
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:29
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:41:29
TD Ameritrade | Disconnected. | 2019-01-10 00:41:29
Disconnected from TD Ameritrade. | 2019-01-10 00:41:29
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:29
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:29
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:41:29
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:41:29
TD Ameritrade | Connecting. | 2019-01-10 00:41:32
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:32
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:32
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:32
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:32 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:32 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:32
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:32
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:41:32
TD Ameritrade | Disconnected. | 2019-01-10 00:41:32
Disconnected from TD Ameritrade. | 2019-01-10 00:41:32
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:32
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:32
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:41:32
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:41:32
TD Ameritrade | Connecting. | 2019-01-10 00:41:35
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:35
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:35
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:35
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:36 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:36 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:36
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:36
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:41:36
TD Ameritrade | Disconnected. | 2019-01-10 00:41:36
Disconnected from TD Ameritrade. | 2019-01-10 00:41:36
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:36
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:36
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:41:36
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:41:36
TD Ameritrade | Connecting. | 2019-01-10 00:41:39
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:39
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:39
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:39
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:39 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:39 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:39
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:39
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:41:39
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:39
TD Ameritrade | Disconnected. | 2019-01-10 00:41:39
Disconnected from TD Ameritrade. | 2019-01-10 00:41:39
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:39
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:41:39
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:41:39
TD Ameritrade | Connecting. | 2019-01-10 00:41:42
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:42
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:42
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:42
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:42 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:42 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:42
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:42
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:41:42
TD Ameritrade | Disconnected. | 2019-01-10 00:41:42
Disconnected from TD Ameritrade. | 2019-01-10 00:41:42
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:42
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:42
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:41:42
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:41:42
TD Ameritrade | Connecting. | 2019-01-10 00:41:45
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:45
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:45
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:45
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:46 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:46 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:46
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:46
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:41:46
TD Ameritrade | Disconnected. | 2019-01-10 00:41:46
Disconnected from TD Ameritrade. | 2019-01-10 00:41:46
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:46
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:46
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:41:46
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:41:46
TD Ameritrade | Connecting. | 2019-01-10 00:41:49
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:49
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:49
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:49
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:49 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:49 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:49
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:49
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:41:49
TD Ameritrade | Disconnected. | 2019-01-10 00:41:49
Disconnected from TD Ameritrade. | 2019-01-10 00:41:49
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:49
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:49
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:41:49
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:41:49
TD Ameritrade | Connecting. | 2019-01-10 00:41:52
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:52
HTTPS apis.tdameritrade.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:52
HTTPS apis.tdameritrade.com:443 (2) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:52
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:53 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:53 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:53
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:53
HTTPS apis.tdameritrade.com:443 (2) | Signaling to core to close socket | 2019-01-10 00:41:53
TD Ameritrade | Disconnected. | 2019-01-10 00:41:53
Disconnected from TD Ameritrade. | 2019-01-10 00:41:53
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:53
HTTPS apis.tdameritrade.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:53
HTTPS apis.tdameritrade.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-10 00:41:53
HTTPS apis.tdameritrade.com:443 (2) | Closed. | 2019-01-10 00:41:53
TD Ameritrade | Connecting. | 2019-01-10 00:41:56
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:56
HTTPS apis.tdameritrade.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:56
HTTPS apis.tdameritrade.com:443 (2) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:56
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:41:56 *
TD Ameritrade | Login failed. | 2019-01-10 00:41:56 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:41:56
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:56
HTTPS apis.tdameritrade.com:443 (2) | Signaling to core to close socket | 2019-01-10 00:41:56
TD Ameritrade | Disconnected. | 2019-01-10 00:41:56
Disconnected from TD Ameritrade. | 2019-01-10 00:41:56
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:41:56
HTTPS apis.tdameritrade.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:41:56
HTTPS apis.tdameritrade.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-10 00:41:56
HTTPS apis.tdameritrade.com:443 (2) | Closed. | 2019-01-10 00:41:56
TD Ameritrade | Connecting. | 2019-01-10 00:41:59
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:41:59
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:41:59
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:41:59
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:00 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:00 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:00
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:00
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:00
TD Ameritrade | Disconnected. | 2019-01-10 00:42:00
Disconnected from TD Ameritrade. | 2019-01-10 00:42:00
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:00
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:00
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:00
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:00
TD Ameritrade | Connecting. | 2019-01-10 00:42:03
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:03
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:03
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:03
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:03 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:03 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:03
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:03
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:03
TD Ameritrade | Disconnected. | 2019-01-10 00:42:03
Disconnected from TD Ameritrade. | 2019-01-10 00:42:03
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:03
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:03
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:03
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:03
TD Ameritrade | Connecting. | 2019-01-10 00:42:06
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:06
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:06
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:06
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:06 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:06 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:06
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:06
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:06
TD Ameritrade | Disconnected. | 2019-01-10 00:42:06
Disconnected from TD Ameritrade. | 2019-01-10 00:42:06
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:06
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:06
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:06
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:06
TD Ameritrade | Connecting. | 2019-01-10 00:42:09
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:09
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:09
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:09
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:10 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:10 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:10
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:10
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:10
TD Ameritrade | Disconnected. | 2019-01-10 00:42:10
Disconnected from TD Ameritrade. | 2019-01-10 00:42:10
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:10
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:10
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:10
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:10
TD Ameritrade | Connecting. | 2019-01-10 00:42:13
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:13
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:13
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:13
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:13 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:13 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:13
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:13
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:13
TD Ameritrade | Disconnected. | 2019-01-10 00:42:13
Disconnected from TD Ameritrade. | 2019-01-10 00:42:13
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:13
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:13
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:13
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:13
TD Ameritrade | Connecting. | 2019-01-10 00:42:16
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:16
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:16
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:16
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:17 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:17 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:17
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:17
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:17
TD Ameritrade | Disconnected. | 2019-01-10 00:42:17
Disconnected from TD Ameritrade. | 2019-01-10 00:42:17
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:17
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:17
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:17
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:17
TD Ameritrade | Connecting. | 2019-01-10 00:42:20
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:20
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:20
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:20
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:20 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:20 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:20
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:20
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:20
TD Ameritrade | Disconnected. | 2019-01-10 00:42:20
Disconnected from TD Ameritrade. | 2019-01-10 00:42:20
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:20
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:20
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:20
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:20
TD Ameritrade | Connecting. | 2019-01-10 00:42:23
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:23
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:23
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:23
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:24 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:24 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:24
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:24
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:24
TD Ameritrade | Disconnected. | 2019-01-10 00:42:24
Disconnected from TD Ameritrade. | 2019-01-10 00:42:24
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:24
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:24
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:24
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:24
TD Ameritrade | Connecting. | 2019-01-10 00:42:27
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:27
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:27
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:27
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:27 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:27 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:27
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:27
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:27
TD Ameritrade | Disconnected. | 2019-01-10 00:42:27
Disconnected from TD Ameritrade. | 2019-01-10 00:42:27
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:27
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:27
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:27
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:27
TD Ameritrade | Connecting. | 2019-01-10 00:42:30
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:30
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:30
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:30
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:30 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:30 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:30
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:30
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:30
TD Ameritrade | Disconnected. | 2019-01-10 00:42:30
Disconnected from TD Ameritrade. | 2019-01-10 00:42:30
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:30
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:30
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:30
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:30
TD Ameritrade | Connecting. | 2019-01-10 00:42:33
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:33
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:33
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:33
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:34 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:34 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:34
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:34
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:34
TD Ameritrade | Disconnected. | 2019-01-10 00:42:34
Disconnected from TD Ameritrade. | 2019-01-10 00:42:34
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:34
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:34
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:34
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:34
TD Ameritrade | Connecting. | 2019-01-10 00:42:37
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:37
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:37
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:37
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:37 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:37 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:37
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:37
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:37
TD Ameritrade | Disconnected. | 2019-01-10 00:42:37
Disconnected from TD Ameritrade. | 2019-01-10 00:42:37
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:37
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:37
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:37
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:37
TD Ameritrade | Connecting. | 2019-01-10 00:42:40
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:40
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:40
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:40
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:40 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:40 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:40
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:40
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:40
TD Ameritrade | Disconnected. | 2019-01-10 00:42:40
Disconnected from TD Ameritrade. | 2019-01-10 00:42:40
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:40
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:40
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:40
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:40
TD Ameritrade | Connecting. | 2019-01-10 00:42:43
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:43
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:43
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:43
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:44 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:44 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:44
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:44
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:44
TD Ameritrade | Disconnected. | 2019-01-10 00:42:44
Disconnected from TD Ameritrade. | 2019-01-10 00:42:44
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:44
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:44
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:44
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:44
TD Ameritrade | Connecting. | 2019-01-10 00:42:47
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:47
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:47
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:47
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:47 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:47 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:47
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:47
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:47
TD Ameritrade | Disconnected. | 2019-01-10 00:42:47
Disconnected from TD Ameritrade. | 2019-01-10 00:42:47
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:47
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:47
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:47
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:47
TD Ameritrade | Connecting. | 2019-01-10 00:42:50
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:50
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:50
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:50
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:50 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:50 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:50
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:50
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:50
TD Ameritrade | Disconnected. | 2019-01-10 00:42:50
Disconnected from TD Ameritrade. | 2019-01-10 00:42:50
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:50
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:50
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:51
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:51
TD Ameritrade | Connecting. | 2019-01-10 00:42:53
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:53
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:53
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:53
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:54 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:54 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:54
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:54
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:54
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:54
TD Ameritrade | Disconnected. | 2019-01-10 00:42:54
Disconnected from TD Ameritrade. | 2019-01-10 00:42:54
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:54
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:54
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:54
TD Ameritrade | Connecting. | 2019-01-10 00:42:57
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:42:57
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:42:57
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:42:57
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:42:57 *
TD Ameritrade | Login failed. | 2019-01-10 00:42:57 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:42:57
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:57
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:42:57
TD Ameritrade | Disconnected. | 2019-01-10 00:42:57
Disconnected from TD Ameritrade. | 2019-01-10 00:42:57
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:42:57
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:42:57
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:42:57
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:42:57
TD Ameritrade | Connecting. | 2019-01-10 00:43:00
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:00
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:00
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:00
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:01 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:01 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:01
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:01
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:01
TD Ameritrade | Disconnected. | 2019-01-10 00:43:01
Disconnected from TD Ameritrade. | 2019-01-10 00:43:01
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:01
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:01
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:01
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:01
TD Ameritrade | Connecting. | 2019-01-10 00:43:04
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:04
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:04
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:04
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:04 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:04 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:04
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:04
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:04
TD Ameritrade | Disconnected. | 2019-01-10 00:43:04
Disconnected from TD Ameritrade. | 2019-01-10 00:43:04
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:04
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:04
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:04
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:04
TD Ameritrade | Connecting. | 2019-01-10 00:43:07
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:07
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:07
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:07
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:08 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:08 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:08
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:08
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:08
TD Ameritrade | Disconnected. | 2019-01-10 00:43:08
Disconnected from TD Ameritrade. | 2019-01-10 00:43:08
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:08
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:08
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:08
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:08
TD Ameritrade | Connecting. | 2019-01-10 00:43:11
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:11
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:11
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:11
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:11 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:11 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:11
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:11
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:11
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:11
TD Ameritrade | Disconnected. | 2019-01-10 00:43:11
Disconnected from TD Ameritrade. | 2019-01-10 00:43:11
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:11
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:11
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:11
TD Ameritrade | Connecting. | 2019-01-10 00:43:14
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:14
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:14
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:14
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:14 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:14 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:14
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:14
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:14
TD Ameritrade | Disconnected. | 2019-01-10 00:43:14
Disconnected from TD Ameritrade. | 2019-01-10 00:43:14
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:14
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:14
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:15
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:15
TD Ameritrade | Connecting. | 2019-01-10 00:43:17
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:17
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:17
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:17
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:18 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:18 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:18
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:18
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:18
TD Ameritrade | Disconnected. | 2019-01-10 00:43:18
Disconnected from TD Ameritrade. | 2019-01-10 00:43:18
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:18
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:18
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:18
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:18
TD Ameritrade | Connecting. | 2019-01-10 00:43:21
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:21
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:21
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:21
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:21 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:21 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:21
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:21
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:21
TD Ameritrade | Disconnected. | 2019-01-10 00:43:21
Disconnected from TD Ameritrade. | 2019-01-10 00:43:21
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:21
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:21
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:21
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:21
TD Ameritrade | Connecting. | 2019-01-10 00:43:24
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:24
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:24
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:24
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:25 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:25 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:25
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:25
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:25
TD Ameritrade | Disconnected. | 2019-01-10 00:43:25
Disconnected from TD Ameritrade. | 2019-01-10 00:43:25
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:25
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:25
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:25
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:25
TD Ameritrade | Connecting. | 2019-01-10 00:43:28
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:28
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:28
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:28
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:28 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:28 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:28
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:28
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:28
TD Ameritrade | Disconnected. | 2019-01-10 00:43:28
Disconnected from TD Ameritrade. | 2019-01-10 00:43:28
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:28
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:28
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:28
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:28
TD Ameritrade | Connecting. | 2019-01-10 00:43:31
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:31
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:31
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:31
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:31 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:31 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:31
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:31
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:31
TD Ameritrade | Disconnected. | 2019-01-10 00:43:31
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:31
Disconnected from TD Ameritrade. | 2019-01-10 00:43:31
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:31
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:31
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:31
TD Ameritrade | Connecting. | 2019-01-10 00:43:34
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:34
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:34
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:34
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:35 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:35 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:35
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:35
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:35
TD Ameritrade | Disconnected. | 2019-01-10 00:43:35
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:35
Disconnected from TD Ameritrade. | 2019-01-10 00:43:35
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:35
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:35
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:35
TD Ameritrade | Connecting. | 2019-01-10 00:43:38
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:38
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:38
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:38
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:38 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:38 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:38
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:38
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:38
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:38
TD Ameritrade | Disconnected. | 2019-01-10 00:43:38
Disconnected from TD Ameritrade. | 2019-01-10 00:43:38
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:38
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:38
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:38
TD Ameritrade | Connecting. | 2019-01-10 00:43:41
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:41
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:41
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:41
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:41 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:41 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:41
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:41
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:41
TD Ameritrade | Disconnected. | 2019-01-10 00:43:41
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:41
Disconnected from TD Ameritrade. | 2019-01-10 00:43:41
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:41
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:41
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:41
TD Ameritrade | Connecting. | 2019-01-10 00:43:44
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:44
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:44
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:44
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:44 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:44 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:44
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:44
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:44
TD Ameritrade | Disconnected. | 2019-01-10 00:43:44
Disconnected from TD Ameritrade. | 2019-01-10 00:43:44
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:44
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:44
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:44
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:44
TD Ameritrade | Connecting. | 2019-01-10 00:43:47
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:47
HTTPS apis.tdameritrade.com:443 (1) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:47
HTTPS apis.tdameritrade.com:443 (1) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:47
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:48 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:48 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:48
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:48
HTTPS apis.tdameritrade.com:443 (1) | Signaling to core to close socket | 2019-01-10 00:43:48
TD Ameritrade | Disconnected. | 2019-01-10 00:43:48
Disconnected from TD Ameritrade. | 2019-01-10 00:43:48
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:48
HTTPS apis.tdameritrade.com:443 (1) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:48
HTTPS apis.tdameritrade.com:443 (1) | Socket gracefully closed by remote side. | 2019-01-10 00:43:48
HTTPS apis.tdameritrade.com:443 (1) | Closed. | 2019-01-10 00:43:48
TD Ameritrade | Connecting. | 2019-01-10 00:43:51
TD Ameritrade | Logging in. (Step 1 of 3) | 2019-01-10 00:43:51
HTTPS apis.tdameritrade.com:443 (2) | Creating socket. Using TLS 1.2. | 2019-01-10 00:43:51
HTTPS apis.tdameritrade.com:443 (2) | Connecting to IP: 198.200.171.201. | 2019-01-10 00:43:51
TD Ameritrade | Login Error: Login Failed | 2019-01-10 00:43:51 *
TD Ameritrade | Login failed. | 2019-01-10 00:43:51 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-01-10 00:43:51
Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:51
HTTPS apis.tdameritrade.com:443 (2) | Signaling to core to close socket | 2019-01-10 00:43:51
TD Ameritrade | Disconnected. | 2019-01-10 00:43:51
HTTPS apis.tdameritrade.com:443 (2) | Shutdown started. Waiting for graceful close. | 2019-01-10 00:43:51
Disconnected from TD Ameritrade. | 2019-01-10 00:43:51
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-01-10 00:43:51
HTTPS apis.tdameritrade.com:443 (2) | Socket gracefully closed by remote side. | 2019-01-10 00:43:51
HTTPS apis.tdameritrade.com:443 (2) | Closed. | 2019-01-10 00:43:51
[2019-01-10 01:30:10]
These are the messages that we see related to the connection problem:
We do not know why there is a login failure. This is not within our control.
[2019-01-10 03:58:31]
SurfTrader - Posts: 68
Not sure why it wont connect with the TDA account, but tried with the IB account again and it works. Ill see if I can figure it out. Thanks
