Date/Time: Sat, 26 Apr 2025 09:50:57 +0000
[Programming Help] - Is AddVolumeAtPrice available to use?
View Count: 597
[2018-12-16 13:43:45]
User718622 - Posts: 57
Is AddVolumeAtPrice from VAPContainer.h available to use? Could I get an example to explain what it's functionality is?
Let me know if the following is accurate:
Example:
If price level $50 has a volume of 60 for that bar and the volume for that price level goes up 5, would AddVolumeAtPrice add 5 to 60? Does this mean that the volume starts from 60 as opposed to starting from 0 at that price level?
Would I be correct to assume that each price level volume starts at 0 if I were to get it in ACSIL?
[2018-12-17 14:58:55]
This function is not meant to be used directly from ACSIL because the volume at price data for each chart bar is set by Sierra Chart.
Date Time Of Last Edit: 2018-12-17 19:57:53
[2018-12-18 01:24:27]
What function should I use to get volume at each price level like shown from a numbers bars? Will get the total volume at that price level at that time?
