Date/Time: Sat, 19 Sep 2026 02:50:31 +0000
[Programming Help] - Difference between EMA's
View Count: 1153
[2018-12-16 10:18:38]
User604531 - Posts: 4
Hello!
Is there way to make formula for "Color bar based on alert",
where is alert is the difference between EMA's >=1.5 points ?
For example: value of 5 ema is 2600
value of 10 ema is 2601.5
Thanks in advance.
[2018-12-16 17:48:47]
Sawtooth - Posts: 4354
You would need to specify the difference in ticks, not points, e.g. the ES, where a point is 4 ticks:
=ABS(ID1.SG1-ID2.SG1)>=TICKSIZE*6
where one EMA is ID1 and the other is ID2; edit as needed.
[2018-12-17 06:27:26]
Thank you Tom!
