Date/Time: Thu, 23 Jan 2025 21:23:37 +0000
Bars with exact same date time (including ms)
View Count: 563
[2018-12-15 16:24:47] |
Usermb - Posts: 126 |
As you can see in the attached screenshot, I ran into a situation where multiple bars have the exact same date and time, including the millisecond part. Didn't see this until now, so I just want to ask you whether this is normal behaviour, or a bug? If normal behaviour, is there any way to get a more precise time for a bar? Thank you. |
BarsSameDateTime.PNG / V - Attached On 2018-12-15 16:20:35 UTC - Size: 34.25 KB - 230 views |
[2018-12-17 05:02:05] |
This is a limitation that currently exists that will be solved sometime in the coming months.
