Date/Time: Fri, 24 Jan 2025 00:47:42 +0000
Trade EURUSD (on FXCM or LMAX) but use 6E data
View Count: 1517
[2018-12-15 13:52:00] |
trad - Posts: 43 |
Is it possible to map symbols, so that we use market data of an instrument like 6E CME while sending orders to another broker (LMAX/FXCM). In a nutshell, is there any way to create link between different data feeds and Order Management Systems?
[2018-12-15 23:04:43] |
Yes this is fully supported. But you are going to pay substantially for the CME exchange fee. This is about 115USD a month.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-15 23:05:03
[2018-12-16 00:19:17] |
trad - Posts: 43 |
I can maintain a full funded trading account with AMP with CME data. I just want to my orders to FXCM instead of CME. May be once a month I can place a couple of trades on CME futures as well, just to keep that futures account active. That way I would still end up paying reduced CME fee of $5. Can you please how can this be done? Will I still be able to use CME data for Pending or Limit orders. Thanks. Date Time Of Last Edit: 2018-12-16 00:20:01
[2018-12-16 04:34:35] |
Okay this is no problem. You just need to connect Sierra Chart once to month to that account to authorize the nonprofessional CME fees. No need to place any trades. You will need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed And refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ConnectingOnlyOnceAMonthToTradingAccount Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-16 04:34:52
[2018-12-23 19:39:58] |
T44 - Posts: 363 |
I have a similar query. In the high volatility, I'd prefer to trade a few index * 5 Euro value mini Dax futures contract (F.US.FDXMH19 on CQG) rather than the 25 * index value Dax futures contract (F.US.DDH19). I am currently using Study/Price Overlay study to put the DD price on top of the FXDM price in my order entry chart, but would prefer a more direct solution. Is this supported? Thanks. |
[2018-12-24 10:36:38] |
In this particular case you will want to open a chart for F.US.DDH19 and set the Trade symbol to F.US.FDXMH19 . Refer to: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
