Date/Time: Thu, 23 Jan 2025 21:36:39 +0000
[Programming Help] - UEN DEN 1)ignore hi lo, 2)add or-equal-to?
View Count: 1006
[2018-12-15 12:02:17] |
User14953 - Posts: 236 |
Greetings Is it possible to set CandleStick Patterns Finder - Bullish (Up) and Bearish Engulfing to: 1) ignore bar high lows; AND, 2) enable “or equal to” option? Dankeschön The Last of the prior bar is less than OR EQUAL TO the Open of the prior bar. The Last of the current bar is greater than OR EQUAL TO the Open of the current bar. The Open of the current bar is less than OR EQUAL TO the Last of the prior bar. The Last of the current bar is greater than OR EQUAL TO the Open of the prior bar. |
