Date/Time: Fri, 24 Jan 2025 00:28:57 +0000
Market Depth Historical Graph do NOT work after upgrade 1850
View Count: 841
[2018-12-15 00:34:41]
User567294 - Posts: 47
after upgrade to 1850 version, my Market Depth Historical Graph has changed , all the lines do NOT match as they should be, all fall apart to up or down of price chart.
How should I get it right?
thanks
Rex
[2018-12-15 01:22:24]
We will look into this.
Provide an image of the chart or Trade DOM, by following these instructions:
[2018-12-15 01:32:52]
http://www.sierrachart.com/image.php?Image=1544837533762.png
here you go
[2018-12-15 01:36:54]
here is other one snapshot
http://www.sierrachart.com/image.php?Image=1544837787923.png
http://www.sierrachart.com/image.php?Image=1544837871987.png
thanks
Rex
Date Time Of Last Edit: 2018-12-15 01:38:09
[2018-12-17 15:14:29]
Provide this particular chart by following these instructions:
[2018-12-18 09:59:29]
I fixed it by reinstall
thanks
Rex
[2018-12-18 17:36:51]
Okay this is good but we are wondering why there was an issue to begin with. If you have any further issue let us know.
