Date/Time: Fri, 24 Jan 2025 00:52:06 +0000
Problem with Rays
View Count: 583
[2018-12-14 18:52:30]
Rnn - Posts: 56
In one of the last several months updates the method in which the rays are selected and adjusted has been changed to worse way that is really disturbing to work with.
before the update if I'd select (adjust) an existing ray it would pick the closest point of the two in a natural way.
Now the selection doesn't "prefer" the natural closest point but it picks the farthest point and then the adjustment isn't what it was supposed to be (it shortens the line since it picks the farthest point instead of just picking the closest point), so for example if I create a ray and then want to adjust the point that extends to the desired precise price it doesn't select it but selects the farthest point, same if I copy and adjust the line.
Also, if I choose to extend a line it often extends it on the other end rather than the wanted closer one - currently if I select a line and select 'Chart Drawing Properties' there is a V button to extend the line - Please add another one so that there will be an option for the two sides (I think it was existed before).
Thank You!
Date Time Of Last Edit: 2018-12-14 18:53:30
[2018-12-18 21:27:30]
John - SC Support - Posts: 37448
There were some changes to selecting Chart Drawings around the version that you are currently on. Those have been fixed since then. Therefore, please update to the current release and see how things work from there.
