Date/Time: Thu, 23 Jan 2025 21:38:54 +0000
Parts of Sierra Larger than Normal
View Count: 622
[2018-12-14 15:44:04]
infpz - Posts: 826
Any idea what causes this? All other windows/programs in the Windows OS are fine. Just Sierra has changed.
image1234.png / V - Attached On 2018-12-14 15:43:24 UTC - Size: 270.88 KB - 279 views
[2018-12-14 18:07:13]
We do hear this from time to time and it has to do with the DPI setting on the monitor or system being different which causes the fonts to appear at a different size.
When you select a Font within Sierra Chart the operating system provides what is known as a logical height which has a dependency on the system DPI setting. The value returned is not the selected Point size. It is a different number. This value is stored but if the DPI setting changes on the system, this will cause the font to appear a different size. Sierra Chart is handling this correctly.
You will need to readjust the font sizes through:
Graphics Settings: Fonts and Text Appearance
Date Time Of Last Edit: 2018-12-14 18:07:46
