Date/Time: Thu, 23 Jan 2025 21:43:13 +0000
Problem - not every order is opening with their OCO pending orders!
View Count: 1015
[2018-12-13 21:01:48]
User517260 - Posts: 97
Dear Support, I and my customer have a problem.
I use following code to place BuyStop order with Pending Stop Loss order:
//--- Set Buy Stop Order ---
s_SCNewOrder BuyStopOrder;
BuyStopOrder.OrderQuantity = LotSize.GetFloat();
BuyStopOrder.Price1 = sc.High[sc.Index-1] + EntryOffset.GetInt()*sc.TickSize;
BuyStopOrder.OrderType = SCT_ORDERTYPE_STOP;
if(MoveToBE.GetInt() != 0){
  BuyStopOrder.MoveToBreakEven.Type = MOVETO_BE_ACTION_TYPE_OFFSET_TRIGGERED;
  BuyStopOrder.MoveToBreakEven.TriggerOffsetInTicks      = MoveToBE.GetInt();
  BuyStopOrder.MoveToBreakEven.BreakEvenLevelOffsetInTicks  = BEOffset.GetInt();
  BuyStopOrder.MoveToBreakEven.TriggerOCOGroup= OCO_GROUP_1;
BuyStopOrder.Target1Offset     = (float)sc.RoundToIncrement(TPSize.GetInt() * sc.TickSize, sc.TickSize);
BuyStopOrder.Stop1Offset     = (float)sc.RoundToIncrement(SLSize.GetInt() * sc.TickSize, sc.TickSize);
BuyStopOrder.OCOGroup1Quantity   = 2;
int Result = (int)sc.BuyOrder(BuyStopOrder);
if (Result > 0){
  Buffer.Format(" %4d-%2d-%2d %2d:%2d:%2d Chart #%d Symbol: %s Buy Stop order #%d was OPENED SUCCESSFULLY (price level = %7.0f) ",
  sc.BaseDateTimeIn[sc.Index].GetYear(), sc.BaseDateTimeIn[sc.Index].GetMonth(), sc.BaseDateTimeIn[sc.Index].GetDay(), Hour, Minute, Second,
  sc.ChartNumber, sc.Symbol.GetChars(), BuyStopOrder.InternalOrderID, BuyStopOrder.Price1);       sc.AddMessageToLog(Buffer,1);
else {
  vanPrintCodeOfError_Longs(sc, Result);
Similar code is for Short section.
A soon as user click custom button Buy - my bot open Buy Stop Order with OCO StopLoss order. As you may see on https://youtu.be/zLKas3fDLIM since 06:00 time point - it worked ok till 09:40 - Buy Stop order was opened with attached Pnding Sell Stop order (SL). BUT! Since 09:40 we may see - BuyStop orders for F.US.YMH19 and F.US.ENQH19 was opened, but without their pending SLs! It is a problem. Help me please as soon as possible, because my customer is stopped in his business because of this problem. Waiting for your reply asap! Thanks, Alex!
[2018-12-13 21:30:13]
It is second example of sdame problem https://youtu.be/wfjlOlbTqcc
it seems - this problem happens if previously placed BuyStop order with his pending SL was filled - next BuyStop order is placing without his SL.
I tested new OCO_GROUP for every new BuyStop order like:
for 1st BuyStop order BuyStopOrder.MoveToBreakEven.TriggerOCOGroup= OCO_GROUP_1;
for 2nd BuyStop order BuyStopOrder.MoveToBreakEven.TriggerOCOGroup= OCO_GROUP_2;
for 3rd BuyStop order BuyStopOrder.MoveToBreakEven.TriggerOCOGroup= OCO_GROUP_3;
but it didn't decide a problem...
Date Time Of Last Edit: 2018-12-13 22:35:52
[2018-12-13 22:43:11]
Do not set this:
Since you are using:
Do not use:
And set this in the code to 0:
ACSIL Interface Members - Variables and Arrays: sc.SupportTradingScaleIn
[2018-12-14 16:17:11]
Thanks a lot!
