Date/Time: Sun, 24 Nov 2024 14:10:10 +0000
this morning`s message log
View Count: 1282
[2013-11-07 14:41:53] |
rubicon - Posts: 19 |
I`m using SC 912, my "SC Real Time Server" is set at 443. Is this the correct setting? or should it be changed to 80 (not recommended) or should I should I download the most recent version of SC. Thanks in advance! Scott |
[2013-11-07 15:14:30] |
Yes, you should use port 443 for the SC Real Time Server. There is a new version available. Generally we do recommend updating. It is a good idea to update when you have time after the market closes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
