Date/Time: Thu, 23 Jan 2025 21:29:30 +0000
How to get Dominant Side Volume values from Numbers Bars in ACSIL?
View Count: 1452
[2018-12-13 00:32:37]
User718622 - Posts: 57
Can I get Dominant Side Volume for a price levels intrabar from Numbers Bars in ACSIL? I want to be able to use them in conditionals within ACSIL. How would I go about doing that?
[2018-12-14 13:36:55]
Is this possible?
[2018-12-14 13:56:29]
Would I use this? ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function
[2018-12-14 18:24:25]
This is supported. Refer to:
ACSIL Programming Concepts: Accessing Volume at Price Data Per Bar
[2018-12-15 00:56:02]
Now, will this give me precalculated values like the studies do? Or does the function start things at 0 for each price movement?
[2018-12-17 18:16:19]
John - SC Support - Posts: 37437
Basically you are accessing the raw data that you see displayed within Numbers Bars:
Numbers Bars
