Date/Time: Thu, 23 Jan 2025 21:27:34 +0000
[Programming Help] - Line type inquiry
View Count: 636
[2018-12-12 21:42:06] |
User917679 - Posts: 76 |
Hi, is there a tool that makes a line which splits a designated fraction of value above and below it(on a graph or indicator)? For example: If I introduce a simple MA, can I get a line drawn that shows me where 70% of value is above(and 30% below)? Or 60% above(and 40% below)? etc. |
[2018-12-13 19:40:28] |
Refer to: Using the Basic Arithmetic Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
