Date/Time: Sun, 24 Nov 2024 12:47:41 +0000
DST not automatically updated in chart
View Count: 1411
[2013-11-07 13:20:30]
bwasi - Posts: 34
I set timestamp to local PC clock but set the time zone following @ New York EST, but when come 1st Sunday of Nov, the time on chart is not changed accordingly. I had to changed the setting at Data/Trade to other time and switched back to NY EST time, then the time is correct according to DST. Is it should auto correct itself ? Tq Support.
[2013-11-07 16:23:02]
We do not fully understand this.
Are you saying the charts did not reflect the Time Zone you set Sierra Chart to until you changed to a different time zone and back to the time zone you wanted? This does not make sense. The charts will reload on a time zone change.
[2013-11-08 03:06:07]
bwasi - Posts: 34
yes.
I'm located in Malaysia, set timestamp to LOcal PC, but set time zone following New YOrk EST
previously , let say in Oct 2013..chart is following time zone setting.
But after 3rd Nov (1st Sunday) USA is in day Saving Time, but chart time axis X still show the same time unchanged (not DaySavingtime)
Has to change to other zone and back the same NY zone as before..now time is correct to DaySavingTime.
I dont have picture now, but I will prepare for it next time. Tq Support Eng.
Date Time Of Last Edit: 2013-11-08 03:06:47
[2013-11-08 03:43:33]
If you are OK now, then we can consider this closed.
If not, then it would seem as though possibly there is a problem with the Time Zone related settings on the computer. Refer to help topic 38 here:
http://www.sierrachart.com/index.php?l=doc/helpdetails38Donhtml
