Date/Time: Fri, 25 Sep 2026 01:38:56 +0000
Hiding a TPO-profile
View Count: 2325
| [2018-12-12 15:52:44] |
| SBTrader82 - Posts: 7 |
Is there a way to hide one specific TPO profile? This is usefuls in the following situations 1) REMOVING OVERNIGHT PROFILE For instance, i like to use the overnight market profile of the last day only during the first hours of trade. After the first hour of trading I would like to remove it from the chart, because it messes up information. So I would like to hide it. 2) HOLIDAYS, some time the profile of a day, is not relevant because that day was a holiday, and the traded volume is irrelevant. It would be great if we could hide it. Ideally it would be nice to have a feature like "merge with previous profile", in which we click on a profile and we hide it.... and then there might be a feature which says "show all hidden profiles" etc... Kind regards |
| [2018-12-12 20:28:16] |
1. No this is not supported but it is possible to not display the overnight profiles for other than the current day. There is an input for this: http://www.sierrachart.com/index.php?page=doc/StudiesReference/TimePriceOpportunityCharts.html#Input_ExcludeEveningSessionProfilesExceptForLastDay 2. You can do it with this particular Chart Setting: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DatesToExclude Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-12 20:28:42
| [2019-10-08 17:11:08] |
| User451559 - Posts: 1 |
Hello, I been using demo version of Sierra, its really amazing! I wonder if theres any change since last year for the following request? thank you! 1) REMOVING OVERNIGHT PROFILE For instance, i like to use the overnight market profile of the last day only during the first hours of trade. After the first hour of trading I would like to remove it from the chart, because it messes up information. So I would like to hide it. |
| [2019-10-10 04:51:42] |
Yes there is but you do have to manually reload the chart to cause this to happen. The TPO Profile Chart study has an input for this.
| [2022-03-10 18:16:02] |
| Alex Q - Posts: 119 |
This is an old topic, but I've had the same issue. Here's the work around: Go to chart settings and disable the evening session under session times. You can toggle this before/after the morning session is over and you no longer want to see the overnight TPO.
