Date/Time: Fri, 24 Jan 2025 00:36:04 +0000
Trade Activity Log - ticks being used as currency values error
View Count: 1130
[2018-12-12 14:39:03] |
User343901 - Posts: 66 |
With settings desribed below all trade value fields in the Trade Activity Log under Trade Statistics, Trades and Period Trade Stats incorrectly show tick values when they should be showing currency values. This results in very high values being stated in profit loss, draw down, p/l totals etc Settings to reproduce: Choose any option in the symbols filter (third drop down list) with the [SIM] prefix Set P/L Format to any of the Currency Value options When setting the symbols filter to a symbol which is not prefixed with [SIM] the correct values are displayed. Screen shots attached showing these behaviours. Can you please look into this and confirm. |
ticks01.png / V - Attached On 2018-12-12 14:38:41 UTC - Size: 144.9 KB - 371 views ticks02.png / V - Attached On 2018-12-12 14:38:46 UTC - Size: 130.97 KB - 342 views ticks03.png / V - Attached On 2018-12-12 14:38:51 UTC - Size: 136.64 KB - 391 views |
[2018-12-12 19:54:51] |
Apparently what is happening is that on the Trade Statistics tab, there is not a conversion to the common currency in the case of a simulated symbol. We are looking into this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-12 19:55:11
[2018-12-17 19:32:55] |
GiantAvocado - Posts: 67 |
FYI - I have similar issue; Replay back tests I have set the P/L format to ticks (T) but get only currency output, no matter what I do; this is in SIM mode (DTS instance 2nd computer), all my analysis is in ticks; this may be random but I cannot figure why it changes to currency ($US); the main live computer is in ticks and displays ticks; but sometimes goes to currency with ticks selected for whatever reason. If I am missing something please direct me to the solution.
[2018-12-17 20:57:25] |
Refer to the documentation for this setting here: Trade Activity Log: Profit/Loss (P/L) Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-18 14:13:21] |
Thanks for the reply; I have the correct tick/currency values set in both 'chart settings' & Global symbol settings as 6.25 (6E futures) & the Activity Log set to look at SIM back tests and still cannot get ticks (T) no matter what; see attached pictures;
Activity Log ticks 2018-12-18_08h55_50.png / V - Attached On 2018-12-18 14:11:40 UTC - Size: 108.64 KB - 368 views Activity Log points 2018-12-18_08h55_50.png / V - Attached On 2018-12-18 14:11:47 UTC - Size: 98.57 KB - 290 views |
[2018-12-18 18:57:35] |
Update to version 1852. This issue should now be resolved: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
