Date/Time: Sun, 24 Nov 2024 18:01:48 +0000
One click price alerts
View Count: 1917
[2013-11-07 08:03:52]
EuropeanTrader - Posts: 290
I appreciate many features you have built for the Alert function but is there a simple way to put a price alert on a chart without getting through all those options every time?
I mean is it possible to just one or two click max. on a chart and set a price alert wherever your cursor was?
Now I have to first draw the line, then choose Alerts, and then go through all those options and then click ok. I have to do it for each of my 10 markets multiple times during day.
It is very time consuming and inefficent.
Thanks!
[2013-11-07 12:58:17]
User201106 - Posts: 62
Don't use a drawing tool alert. Use a symbol price alert directly from the chart. First add the menu selection "Add Symbol Alert" to Global Settings/Customize Chart Shortcut Menu. That gives you the right click option on the shortcut menu. You should also add "Show/Hide Alert Manager" to the Shortcut Menu. Also, with Alert Manager you can edit, delete, rearm or add a new alert on the Symbol Alerts tab.
[2013-11-08 02:02:14]
GPST10 - Posts: 139
I have simplest and most practical idea:
SC can program it as a one click option in a chart dome - let's say right mouse click directly on the price (would activate one time simple alarm when first traded at that price), second right mouse click would cancel alarm before it's triggered.
I would use it every day, so would you guys, guaranteed.
[2013-11-12 14:07:27]
thanks guys
[2013-11-12 15:11:45]
User30668 - Posts: 108
GPST10,
This is very interesting. However I couldn't figure out how SC can program it the way you are suggesting.
Would you please explain with more detail how I should do to set it?
Thanks.
[2013-11-26 11:57:21]
SC Team,
I do have a suggestion regarding this which would really do the job simply (MT4 platform uses it and is nothing compared to SC).
On this chart I have 2 alerts:
http://www.sierrachart.com/image.php?l=1385466878979.png
but I can't see them graphicaly which after 5 mins makes me question If I've put them there in the first place.
Second, If I right click on the mouse I can choose "Add symbol alert". Wouldn't it be nice that the option "Comparison" would automaticaly adjust "above/below cuurent mkt price" just by acknowledging where you clicked on a chart? That would simplify it to "only" few click alert feature.
Can we expect anything like that, please?
Thank you.
[2013-11-26 12:34:45]
GPST10 - Posts: 139
I'm not a programmer but seen several places the capability like oec, cqg etc...and knowing that SC can match any of them and more (and they do) should be possible.
